Back to Top
Start 12th Anniversary
Roborock F25 Series
Roborock F25 Series
Smart, Smooth, Stainless
Roborock F25 Series
Smart Wet-and-Dry Cleaning
Spotless with a Single Stroke
JawScrapers
Complete Clean
Stays Clean and Ready to Roll
Seamless and Upgraded
Maneuverability
Intelligent App and
Voice Alerts
Roborock F25 Series
Roborock F25 | Roborock F25 GT | Roborock F25 ACE | Roborock F25 ALT | Roborock F25 LT
Play Video
Sticky, Even Hairy Mess?
Make It No Mess.
99.99 %2
Bacteria Removal Rate
99.99 %2
Spend less time cleaning and more time living. With 20,0001 Pa suction and a 450 RPM cleaning frequency, the Roborock F25 Series delivers spotless results in a single stroke.
Cleaning Strokes3 / min
20,000 Pa5
Suction Power
>20 N4
Downward Cleaning Pressure
<1mm
Edge-to-Edge Cleaning9
<1mm
60 min7
Battery Life under Eco Mode
410 sqm8(4,413 sqft)
Cleaning Area per Charge
JawScrapers Roller
Designed for Lasting Shine
Tangle Rate10
12.5cm 0°
Proactive Self-Washing
As you clean, the F25 series uses the DirTect® module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
Moves as You Move
Small Tweak, Big Improvement
Always Ready, Even Upright
Stays powered even in upright position —ideal for crossing thresholds or tackling tight spots like stairs. No shutdowns, no restarts, just seamless, uninterrupted cleaning.
90 °C13
5 min
Fast Drying
99.99 %14
Multiple Stages
Separation System
99.99 %14
Multiple Stages
Separation System
Intuitive to Use,
Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
Key Specs
Roborock F25 GT
4.0kg
Dimensions (with dock)
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
Roborock F25 LT
Coming soon
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Roborock F25
Coming soon
DirTect® Smart Sensor
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Roborock F25 ALT
Coming soon
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Roborock F25 ACE
Coming soon
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Key Specs
Roborock F25 GT
Roborock F25 LT
Coming soon
Roborock F25
Coming soon
Roborock F25 ALT
Coming soon
Roborock F25 ACE
Coming soon
4.0kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
7. Based on internal testing carried out by the manufacturer under Eco mode. Applies to all units except the Roborock F25 GT, which has a battery life of 40 minutes in Eco mode.
8. Based on internal testing carried out by the manufacturer under Eco mode. Applies to all units except the Roborock F25 GT, which has a battery life of 300sqm (3229sqft) in Eco mode.
13.Based on internal testing. The self-washing temperature refers to the temperature of the air outlet blowing over the water, not the temperature of the water itself. Actual results may vary depending on environmental factors.
Claim your reward!
Your reward!
Here is your coupon code
Refer and get a 8% discount
