2x
20%↑
Introducing the DuoRoller™ Brush, the latest in Roborock's cleaning technology, designed to enhance vacuuming performance on carpets and ensure fewer hair tangles to provide a hassle-free cleaning.
HyperForce® suction power has been upgraded to 5,500 Pa2, allowing Q5 Pro to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
Customizable App Features
ScratchSafe™ Wheels and Brushes
Sensient® Sensor Array
Adaptive Route Algorithms
Child Lock
Off-Peak Charging
Robot vacuum
