Start
Login
Rules
Event Rules
[[lottery.rule]]
[[ item.brief ]]
Shop Now
Q7 Max Series
Q7 Max Series
4200 Pa Suction Power
Auto Dust Emptying Dock
300g Consistent Mop Pressure
PreciSense® Precision LiDAR
3D Mapping
Custom Cleaning Routines
3D Mapping
q7max
Q7 Max+
Simple Cleaning. Simpler Emptying.
red dot
q7max
42001 Pa
Suction Power
q7max
Auto-Empty Dock Pure Support
q7max
q7max
q7max
3D Mapping
q7max
Roborock Q7 Max+ combines a wide range of effective robot vacuum technologies proven in generation after generation of Roborock vacuum. It delivers uncompromising vacuuming effectiveness, incredible ease of use, and the absolute convenience of the Auto-Empty Dock Pure.
Serious Suction Power
Drag away dirt hiding in your carpets and lift off debris hiding in floorboard cracks with a maximum suction power of 42001 Pa.
Durable Grime Removal
A long-lasting all-rubber brush powerfully agitates carpets to release more dirt, flicks dust into the vacuum stream, and strongly resists hair tangles. Able to move across multiple panes, it keeps close to the ground for more effective cleaning.
7 Weeks2
Without Emptying
2.5L
Dustbag
7 Weeks
Without Emptying
Clean often, empty rarely with the Auto-Empty Dock Pure. It empties your robot automatically into its 2.5 L dustbag, every clean, for up to 7 weeks2. When the bag is full, it can be swapped out in seconds. The dustbag is also an effective air filter, tested to filter 99. 7% of pollen as small as 0.3 microns3 , helping your air clean.
2.5L
Dustbag
7 Weeks
Without Emptying
Twin Cleaning Power
Vacuum and mop simultaneously to capture fine dirt that vacuuming alone might miss. Equipped with an electronic pump, the Q7 Max+ offers 30 water flow levels so you can fine-tune cleaning to match your floor types and preferences.
240 sqm
Maximum Mopping Range4
300 g
Electronic Mopping
30 Water Flow Levels
Twin Cleaning Power
240sqm
300g
Electronic Mopping
Combined Dustbin
& Water Tank
Combining the dustbin and the water tank into one unit increases the capacity of both. It also makes it easier to empty the bin and refill the tank in one trip.
470 ml
Dustbin Capacity
350 ml
Water Tank Capacity
Clean On
and On
Driven by a large 5200mAh Li-ion powerhouse, Q7 Max+ can clean non-stop for up to 3 hours5 on a single charge. Easily enough range to tackle most homes.
300 sqm
Maximum Vacuuming Area5
Combined Dustbin
& Water Tank
470 ml
Dustbin Capacity
350 ml
Water Tank Capacity
Clean On
and On
300 sqm
Precision PreciSense® LiDAR
Roborock's PreciSense® LiDAR system is the brains behind your robot's extraordinary ability to find the most efficient way to clean throughout your home. The maps it creates power a suite of features controlled in the Roborock app.
Scheduling
Life in a home can be complicated. You can create custom cleaning schedules that work for your home with advanced scheduling. Pick your time of day, suction power, and the room(s) you need, and it will repeat automatically.
Multi-Level Mapping
Many homes have multiple levels. Multi-level mapping systems automatically recognize different levels of your home. All you have to do is put the robot down. No additional docks, no need to identify the level in your app. Up to four levels are supported.
No-Go Zones and
Invisible Walls
No-Go Zones define an area that the robot cannot go, while Invisible Walls draw a line and are good for sealing off rooms and corners. Every level in your home can have No-Go Zones and Invisible Walls. All are placed automatically after the level has been recognized.
3D Mapping
Take a new look at your home and get a clearer understanding of your layout with 3D Mapping. You can even add furniture and floor materials to create a more accurate representation of your home.
Routines
Do you cook a lot? Find yourself always turning up the suction and sending the robot to the kitchen? Set a routine for that and do it with one tap instead of several. You can also add schedules to any routine you set.
Speak to Command
Take control of your robot, start cleanups, send it to tackle specific rooms, and more with just the power of your voice. Amazon Alexa, Google Home, and Apple Siri Shortcuts are supported.
Keep Kids
& Pets Safe
Curious kids and clumsy pets might accidentally start a clean with the push of a button. Stop that from happening with the Child Lock.
Worry-Free Roaming
Have confidence that your Q7 Max can wander safely around your home. The Sensient® sensor array includes a suite of sensors, including cliff sensors, accelerometers, bumpers, and more. It will avoid rolling off of steps, getting trapped, or slamming into your walls.
Q7 Max+ Q7 Max
Q7-Max-Plus Q7-Max
3D Mapping
3D Mapping
Q7 Max+   vs   Q7 Max
Q7-Max-Plus
Q7 Max+
Q7-Max
Q7 Max
3D Mapping
3D Mapping
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery.
2. Actual emptying interval will depend on use habits and environmental factors.
3. Based on testing carried out by an independent lab according to ISO/TS 11155-1-2001 and PT-22-000-100650 standards.
4. Based on internal testing carried out on hard floors with a full water tank, full battery, and low water flow. Actual results may vary, depending on the room characteristics. Range is an estimate based on the assumption that 20% of the area is covered by furniture and will not need to be mopped.
Claim your reward!
Your reward!
Here is your coupon code
Refer and get a 8% discount
Refer a friend & receive an 8% discount For every friend you refer, you both will receive an 8% discount on your next purchase of most vacuum cleaners !(QV 35S, Q10 Series and Q7 M5 are excluded.)
Refer a friend & receive an 8% discount For every friend you refer, you both will receive an 8% discount on your next purchase of most vacuum cleaners! (QV 35S, Q10 Series and Q7 M5 are excluded.)
