Back to Top
Start 12th Anniversary
Qrevo Edge 2
The Sharp Choice
Buy now
From corners to low-clearance spaces, Qrevo Edge 2 is designed for thorough, whole-home cleaning. Hyper Power hair cleaning works alongside an advanced mopping system to deliver consistent coverage across floors. With Reactive AI Obstacle Recognition, cleaning moves smoothly around everyday objects, maintaining a steady, uninterrupted flow from start to finish.
Hyper Power Hair Cleaning
25,000 Pa HyperForce®¹ Suction & Dual Anti-Tangle System
Upgraded Mopping System
Defeats deep grime. Preserves its prime.
FlexiArm Technology
Cleans edges and below, with intelligent ease.
7.98 cm Ultra-Slim Design
Effortless reach for every low space.
Multi-Scenario Cleaning Strategy
Intelligently adapts for thorough cleaning across varied scenes.
Adaptive intelligence for reliable cleaning.
Strong. Smooth. Spotless.
25,000 Pa HyperForce® Suction¹
Level Up Your Hair Cleaning Game
Tired of endless hair cleanup? Meet a powerful solution. 25,000 Pa HyperForce® Suction¹ lifts hair and fine dust from deep within floors.
25,000 Pa
The Hair Tangle Terminator
The Dual Anti-Tangle System—featuring the DuoDivide® Main Brush and FlexiArm Arc Side Brush—works in sync to capture hair up to 40 cm long. Combined with an easy-to-maintain omni-wheel with an external brush design, winding is significantly reduced for consistently smooth cleaning.
Hair Tangling Rate²
Hair Removal Rate³
Hair Tangling Rate⁴
Meet the new MVP:
Mops Vigorously, Prompt-Dry.
The upgraded mopping cloth features a high-density weave and 8N downward pressure⁵ to capture dust and oily grime. Its softer, fast-absorbing material leaves minimal water for quicker drying, while reinforced edges ensure long-lasting durability.
Durable Locked-In Weave Structure
Dense, pill-resistant weave maintains shape wash after wash.
Reinforced Fiber
Blended fibers absorb quickly, dry fast, and protect floors.
99.99% Floor Bacteria Removal⁶
Antimicrobial-infused. Supports a hygienic home for families and pets.
8N Downward Pressure⁵
Strong pressure paired with a denser, flatter weave captures dust and grease effectively.
Reaching Beyond Edges
FlexiArm Technology
Every Edge, Every Corner
Roborock’s exclusive FlexiArm Arc Side Brush intelligently extends beyond ordinary reach, cleaning closely along walls and deep into corners. Guided by a precision algorithm, it systematically sweeps debris from toe-kick areas and other hard-to-reach spots—delivering thorough, consistent coverage across a variety of floor types.
error
Edge and Corner Sweeping⁷
Toe Kicks Detection & Cleaning⁸
Down to 2.5 cm
Meet the Low-Profile Specialist
With an industry-leading thin body of 7.98 cm, it conquers extreme low spaces. The retractable LDS for precise mapping and localization, complemented by the dToF sensor that proactively detects low-space accessibility. When entering a confirmed low space, the LDS retracts, and the integrated 100° Vision Module takes over, utilizing its wide field of view to maintain positioning and enable accurate cleaning routes in confined areas.
Unmatched Adaptive Access.
Intelligent Gap Cleaning.
Intelligently adapts to diverse scenes, ensuring no hidden dirt remains—whether cleaning carpets, crossing curtains, or performing double cleaning—for consistently superior deep cleaning.
Carpet Cleaning
Curtain Passing Through
Double Assurance Cleaning
Auto Mop Lifting Auto Mop Detaching
error
Reaches behind marked curtains to clean hidden areas effectively.
error
Active Obstacle Cleaning*
error
*Clean areas blocked by people or pets
Smart Avoid, Smart Clean.
More Visibility, Fewer Interruptions.
Skip the pre-cleaning. Powered by structured light and an RGB camera, it intelligently detects and avoids over 280 types of clutter with precision, day and night.
Types of Objects Recognized⁹
280+
DirTect® Technology
Smart Lift. Mess-Free Cleaning.
DirTect® Technology detects different types of mess to deliver a more thorough, targeted clean. By identifying whether grime is dry or wet, it automatically adjusts its cleaning strategy. When heavy dry dust is detected, the system switches to a sweep-only mode with increased suction. For wet messes, the main brush is lifted, activating the mop-only mode to prevent dry and wet waste from mixing.
Liftable Main Brush Liftable Mop
Pro-Grade Dock Maintenance
The Brand-New Multifunctional Dock
The Brand-New Multifunctional Dock uses 80°C/176°F¹⁰ hot water to deep-clean mop pads, helping loosen stubborn dirt, grease, and food residue. This thorough refresh supports a more hygienic and complete floor clean with every cycle.
Hot-Water Mop Washing¹⁰
Up to 80°C/176°F
Bacteria Removal Rate¹¹
New Cleaning Tray & New Soaking Mode*
Quiet & Clean, All in One.
Quiet & Clean,
All in One.
A cleaner mop starts with a thorough soak—redefining station maintenance with quieter cleaning cycles, hands-free operation, a self-cleaning base, and simplified reliability through an upgraded one-piece cleaning tray.
80°C/176°F¹⁰ Hot Water
Dock Self-Cleaning
The dock base stays hygienic with hot water up to 80°C/176°F¹⁰ and a self-cleaning module, helping reduce manual maintenance.
55°C/131°F¹² Warm Air Drying
Gently dries mops thoroughly with 55°C/131°F¹² warm air, keeping mold and unpleasant odors at bay.
Intelligent Dirt Detection
for Re-Wash & Re-Mop
Dirt levels are continuously monitored during mop washing, allowing the system to adjust wash duration and trigger an additional mopping pass in areas with higher dirt buildup.
Warm Water Auto-Refilling
Automatically refills the water tank with warm water as needed.
Allows for up to 65 days¹³ without manual emptying.
Detachable Dock Base
Roborock APP
The Brain Behind Every Clean
Roborock SmartPlan® 3.0
Roborock SmartPlan® 3.0 automatically recognizes room types, learns your cleaning habits, and selects the optimal cleaning strategy for you—boosting suction when needed, rewashing the mop as required, and lowering power to reduce noise during Do-Not-Disturb periods.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Track Your Pet
Video Call & Cruise
Pet Snaps
Track Your Pet
Video Call & Cruise
Everyday Features
Clean Beyond Curtains
Stain-Target AI Cleaning
Built-in Voice Assistant
Third-Party Control
Matter Supported. Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home.
Your privacy, our top priority.
Key Specs
Qrevo Edge 2
Qrevo Edge 2
352 * 352 * 79.8 mm
340 * 487 * 521 mm
Weight
Qrevo Edge 2
4.5 kg
8.2 kg
1. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
2. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
3. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
4. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
6. Based on testing carried out by TÜV SÜD on Escherichia coli under mopping mode, over 99.99% of bacteria on the floor are effectively removed. Report number: No. Z2GCN 123821 0013 Rev. 00. Actual results may vary according to the home environment.
7. Based on internal testing carried out by the manufacturer using a side brush for edge and inside-corner sweeping performance. Actual coverage and distance may vary due to usage and environmental conditions.
8. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
9. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 3 cm wide and 3 cm tall. Recognition accuracy may vary due to usage and environmental conditions.
10. Based on internal testing carried out by the manufacturer. The water at the clean water dispensers of the base can be heated up to 80°C/176°F under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary due to usage and environmental conditions such as altitude and atmospheric pressure.
11. Based on testing carried out by TÜV Rheinland on Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Report number: CN269E6E 001. Actual results may vary according to the home environment.
12. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C/131°F under standard room temperature. Actual results may vary due to usage and environmental conditions.
13. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
Claim your reward!
Your reward!
Here is your coupon code
Refer and get a 8% discount
