S8 Series
S8 Series
DuoRoller Brush
VibraRise Mopping System
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller Riser® Brush
VibraRise 2.0 Mopping System
S8 Pro Ultra
Forget About Cleaning, Really.
s8proultra
Forget about cleaning, including robot maintenance. With Roborock’s all-in-one docking system – RockDock® Ultra, and the most advanced cleaning technologies – DuoRoller Riser® Brush and VibraRise 2.0 Mopping System, S8 Pro Ultra is here to free your time.
Available in Black and White
Ultimate Convenience
The all-new RockDock® Ultra boasts zero maintenance. With this all-in-one dock, you don't have to clean the robot after it has done its rounds, bringing you a totally hands-free cleaning experience.
Washes robot mop automatically during cleanup and when finished so you don’t have to after each use.
Safely dries the washed mop and bottom of the dock with warm air, preventing mold growth and unpleasant odors even in wet weather.
Automatically empties dust and dirt after each cleanup, allowing for up to 7 weeks1 without changing a dust bag. What’s more, the dual brushes clean themselves as well.
Refills the robot water tank during cleanup for a maximum mopping range of over 300sqm (3230sqft)2.
Free your time with the self-cleaning design that cleans the bottom of the dock for easier maintenance.
Self-Washing
Self-Drying
Self-Emptying
Self-Refilling
Self-Cleaning
Dual Cleaning Power
Double the Power,
Double the Clean
Make your home cleaner than ever before with the new two-fold brush and mopping system, featuring the DuoRoller Riser® brush and VibraRise 2.0 mopping system.
The Perfect Cleaning Duet
HyperForce® suction has been improved to 6,000 Pa3, this means your robot vacuum can reach deeper and capture debris and dust from hard floors and carpets.
Q7-Max
Roborock Carpet Boost+ System
Q7-Max
Carpet cleaning is a breeze with Roborock Carpet Boost+ system that’ll leave your carpet mess-free from pet hair to bread crumbs.
30%
Hair Pick-up Rate4
See how Roborock Carpet Boost+ system works
How Carpet Boost+ System Works
Step 1
Step 2
The mop lifts5 automatically, ensuring it does not touch the carpet6 when vacuuming.
Step 3
DuoRoller Riser® brush and increased suction power help remove mess from carpets more effectively, enabling a thorough and deep cleaning experience by cleaning the carpets twice7.
Cleans Up Spills with Better Efficiency8
S8 Pro Ultra
The VibraRise 2.0 has improved its vibration modules two-fold, meaning that the cleaning zone is widened. Paired with high-speed scrubbing and consistent pressure on the floor, the mop can clean anything and everything, from soda to dried-on spills, effortlessly.
2x
Vibration Modules
3000 times/min
High-speed Scrubbing9
> 6N
Mop Pressure10
5mm
Mop Lifting5
Liftable Brush and Mop
The Intelligent Combo that Offers You More
For different cleaning tasks, the brush and mop can be lifted automatically to maximize the cleaning effectiveness and also avoid leaving stains after a clean.
Brush lifted Mop lifted Brush & Mop lifted
Brush lifted
Mop lifted
Vacuum-only
Mop-only
Carpet cleaning
Returning to dock
Mop drying
The liftable brush and mop can separate vacuuming and mopping in a single clean, giving you more cleaning options:
Vacuum and mop simultaneously
Time-saving Choice
Vacuum then mop11
Deep-cleaning Choice
Vacuum-only
Mop-only
Quiet Mopping
Clean While You Rest
Need to clean while you rest? Your robot vacuum can minimize cleaning noise when it’s mopping12, allowing you to catch up on some much-needed rest anytime.
Worry-free Intelligence
Smart Enough to Stay Out of Trouble
With 3D structured light and infrared imaging technology, the Reactive 3D Obstacle Avoidance system can help the robot vacuum identify and avoid potential hazards on the floors, in both bright and dark rooms, bringing you a worry-free cleaning experience.
42
Objects13
Pedestal
Footwear
Pet Waste
Fabric
Power Strip
Wire
Dustpan
Obstacle
Scale
PreciSense® LiDAR Navigation
The Best Route, Everytime
Customizable App
Features
Total Control Is a Tap Away
Customizable App Features
Map Quicker,
Clean Faster
Experience fast and effective cleaning as your robot vacuum can create a map up to 6 times faster14 before the first cleaning task and can clean your daily area 30% faster15 when needed.
Quick Mapping
Fast Cleaning
Automatically detects easy-to-get-stuck places and suggests No-Go Zones to prevent your robot vacuum from getting caught in small spaces. You can also draw Invisible Walls that block certain areas from your robot vacuum’s entry in the Roborock App.
The robot gets trapped here repeatedly. Set a no-go zone so the robot would go around.
Map Quicker,
Clean Faster
Quick Mapping
Fast Cleaning
lightning
Fast Charging
30%
faster16
Quickly resumes cleaning by charging 30% faster16 than before.
Off Peak Charging Supported
Custom Cleaning Routines
Decide on your time when the robot vacuum cleans with custom cleaning schedules, and set cleaning routines for particular areas in the house regularly or on demand.
3D Mapping
The 3D Map allows you to accurately build your house virtually. And with the ability to add furniture, you can create the most detailed map of your house, ensuring that you get the best possible cleaning.
Multi-level Mapping System
Have a house with more than one floor? Multi-level mapping automatically recognizes distinct levels of your home. All you have to do is put the robot down. No additional docks or app identification are needed. Up to four floors supported.
HyperForce® Suction
Sensient® Sensor Array
Customizable App Control
Adaptive Route Algorithms
Child Lock
Quiet Mopping
Voice Control
S8 S8+ S8 Pro Ultra
Q7-Max-Plus Q7-Max Q7-Max
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller Brush
DuoRoller Brush
S8+
S8 Pro Ultra
DuoRoller Brush
DuoRoller Brush
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
1. Actual emptying interval will depend on use habits and environmental factors.
2. Based on internal testing carried out on hard floors with a full clean water tank in the S8 Pro Ultra’s dock using default mode. Actual results may vary, depending on room characteristics.
3. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
4. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
5. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
6. Automatic mop lifting is only suitable for low-pile carpets not higher than 4mm. Alternatively, you can select avoid mode on the carpet settings in the Roborock and Mi Home App.
7. To clean the carpet twice, select deep mode on the carpet settings in the Roborock and Mi Home App.
8. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
9. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
11. To vacuum first and mop later, select WashVac routine in the Roborock App.
12. Tested on mop-only mode with mild scrub intensity and deep+ mop route. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
13. Based on internal testing carried out by the manufacturer, S8 Pro Ultra can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
14. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
15. Compared to standard cleaning route mode. Actual results may vary according to the home environment.
16. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
Your coupon code:
ROBOROCKS
Copy Code
Claim your reward!
Your reward!
Here is your coupon code
Refer & get 8% off
Invite your friends and earn for every successful referral! (Q5 Pro and Q5 Pro+ are excluded.)
Refer & get 8% off
Invite your friends and earn for every successful referral!(Saros Z70, Q5 Pro+ and Q5 Pro are excluded.)
