[[lottery.rule]]
Vacuum-only | Mop-only | Carpet cleaning | Returning to dock | Mop drying | |
Mops Lifted |
Mops & Chassis Lifted |
Brush Lifted |
Mops Lifted | Mops & Chassis Lifted | Brush Lifted | |
Vacuum-only |
Mop-only |
Carpet cleaning |
Returning to dock |
Mop drying |
Roborock Carpet Boost+ System
Customizable App Features
Adaptive Route Algorithms
Child Lock
Off-Peak Charging
1. Certified No.PT/24/GEN/0454 by SGS. Actual results may vary according to the home environment.
2. Certified No.PT/24/GEN/0453 by SGS. Actual results may vary according to the home environment.
3. Certified No.PT/24/GEN/0455 by SGS. Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
10. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
12. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
13. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000086976 (Roborock Qrevo Edge); 0000087862 (other models). Actual results may vary according to the home environment.
