[[lottery.rule]]
DuoRoller Brush
VibraRise Mopping System
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller Riser® Brush
VibraRise 2.0 Mopping System
S8
Forget About Cleaning, Really.
Free your time and let Roborock S8 do the dirty work. Experience the next level of cleaning with our latest technology – DuoRoller™ Brush and VibraRise® Mopping System. The smart cleaning experience has never been easier.
Roborock Carpet Boost+ System
that’ll leave your carpet mess-free from pet hair to bread crumbs.
Step 1:
Step 2:
The mop lifts3 automatically and ensures not touching the carpet4 when cleaning.
Step 3:
DuoRoller brush and increased suction power help remove messes from carpets more effectively, enabling a thorough and deep cleaning experience by cleaning the carpets twice.5
Experience the power of sonic vibration technology that scrubs with consistent pressure to leave floors gleaming.
Q7+ vs Q7
DuoRoller Brush
DuoRoller Brush
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
2. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
3. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
4. Automatic mop lifting is only suitable for low-pile carpets not higher than 4mm. Alternatively, you can select avoid mode on the carpet settings in the Roborock and Mi Home App.
5. To clean the carpet twice, select deep mode on the carpet settings in the Roborock and Mi Home App.
6. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
8. Based on internal testing carried out by the manufacturer, the S8 can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
9. Compared to Clean & Mapping mode. Actual results may vary according to the home environment.
10. Compared to standard cleaning route mode. Actual results may vary according to the home environment.
1.The VibraRise mopping system is available on the S7, S7 Pro Ultra, S7 MaxV, S8 and S8 Pro Ultra.
